Need Help!
Old May 3, 2006 | 08:10 PM
BriGuy's Avatar
Default Need Help!
I am in the process of trying to install the Katech rod bolts. I am using a cherry picker to hold the motor in place. I am trying not to pull the whole motor out. I have the whole car about 2 feet in the air. My question is, where do I connect the chain of the cherry picker at to hold up the motor? (I am using D-Links on the chain) Any help would be greatly appreciated!
Right now I am frustrated because I can't see where to connect it up at.
Old May 3, 2006 | 09:18 PM
ShevrolayZ28's Avatar
I don't know but is there any way you can support the motor from below? Like with blocks of wood or big-*** jackstands? Hang in there, man.
Old May 3, 2006 | 09:22 PM
BTW, I know this guy just did rod bolts.
https://ls1tech.com/forums/member.php?userid=18361
Maybe you can send him a PM asking for advice. Good luck.
