cam install time ?
http://www.ls1howto.com/index.php?article=23
If you have the best available tools at your disposal, then it cuts a fair whack of time off.
Get a good quality puller for the crank balancer. I had a cheaper version and it belt like a banana.
I also used two different types of Spring compressors.
The first was a leverage type bar made by Crane. Worked well but couldnt get to one spring due to the fuel line. Then borrowed a different type which screws down the spring.Much better to sue and much faster. I think Snap On sells them.
Take your time and check everything twice.
If you start early and take it in a methodical approach you'll get it done in the day, no probs.
. Not being offensive to anyone, but I realistically cant see anyone doing that job in less than six hours, and thats hauling ***. If someone can do it in less, then i really dont wont them workin on my car in a hurry..... Trending Topics
Great Advise here, I had to run out to get two after they flew somewhere, found them under the car about 3 hours later.
