cam question
Old May 5, 2006 | 10:23 PM
fastjarred98's Avatar
Default cam question
i was browsing cams and came across a comp cam that had a 112 +2 lsa....... i know that the 112 is the lobe seperation but what is the difference with the +2 at the end?
Old May 5, 2006 | 10:28 PM
TA TECH's Avatar
It has 2+ degress ground into the cam!
Old May 5, 2006 | 10:52 PM
~JOSHUA's Avatar
That's the number of degrees of advance ground into the cam. If you install it "straight up" you will still have 2 degrees of Cam advance built in not ignition advance....
