eagle rod help
Old May 6, 2006 | 11:34 AM
1a-play's Avatar
Default eagle rod help
please answer this- does it matter whick way the eagle rod is mounted to the piston? with the bearing tabs towards the center of the block or does it matter??
Old May 6, 2006 | 05:48 PM
1a-play's Avatar
anyone
Old May 6, 2006 | 08:16 PM
AmericanMuscle313's Avatar
Yes it does matter. Correct me if Im wrong, but I believe with high performance rods, such as eagle h-beams, the chamfer needs to be facing towards the crank.
Old May 6, 2006 | 08:38 PM
KCS's Avatar
KCS
Moderator
Yep, chamfer needs to be towards the counterweight. General rule of thumb is to have the tangs in the rod opposite the valve reliefs in the piston
