lube for cam install?????
Old May 8, 2006 | 03:01 PM
vader99's Avatar
Default lube for cam install?????
Do most of you guys just use engine oil on the cam before putting it in or should assembly lube be used?
Old May 8, 2006 | 03:21 PM
HOSS's Avatar
Just pour some oil on it and slide her in.
Old May 8, 2006 | 03:23 PM
Ferocity02's Avatar
Well said!
'02 SLP#686's Avatar
Better ask her nicely first
Assembly lube for when the car will sit a while before firing.
Old May 8, 2006 | 03:24 PM
Orange Peel's Avatar
I used the GM Assembly lube just to be safe, works great.
Old May 8, 2006 | 03:27 PM
HOSS's Avatar
all you guys are perverted
Old May 8, 2006 | 03:43 PM
s346k's Avatar
i've always used white lithium grease...never had a problem. just change the oil shortly after a few heat cycles of the springs.
C.J.'s Avatar
Where can you buy the GM assembly lube? Dealership?
Old May 8, 2006 | 03:52 PM
vader99's Avatar
So, is engine oil safe enough or should the assembly lube be used?
I thought you didn't need to use assembly lube on a roller cam ?
Old May 8, 2006 | 04:00 PM
Oil will be fine if you assemble and fire the engine. Too much time and the oil will just run off. I used assembly lube and white lithium grease on the entire thing, but the motor sat in my heated garage for 4 months before install.
Old May 8, 2006 | 04:07 PM
evergreen0077's Avatar
i used gm assembly lube, any dealership should have it
Old May 8, 2006 | 04:10 PM
Yep, the dealership will have it, like $10 I think
Old May 8, 2006 | 04:13 PM
Turbo LS1 SS's Avatar
lucas
Old May 8, 2006 | 04:17 PM
BADFNZ's Avatar
Lubriplate. $5 at any auto parts store.
Old May 8, 2006 | 07:37 PM
vader99's Avatar
So, if using assembly lube, should you change the oil soon after the car has run for a bit after the cam install is done?
Old May 8, 2006 | 07:39 PM
It is always a good idea after doing internal work to change the oil after a short amount of time.
