Thrust bearing gone?
Old May 8, 2006 | 04:55 PM
98camaroLS1M6's Avatar
Default Thrust bearing gone?
Wat does the engine do/sound like when the thrust bearing goes? I've been getting metal shavings in my oil for months, want to know what feels/sounds like when it goes completely. Is oil pressure affected for this bearing?
Old May 8, 2006 | 06:10 PM
andereck's Avatar
Not really, besides the damage done to the bearings from the particles circulated. If its a stick then have someone work the clutch with you watching the dampener/pulley. The crank will noticeably more fore and aft if the thrust is shot.
Old May 8, 2006 | 06:35 PM
kossuth's Avatar
Very unlikely. The thrust bearing is actually the number 3 main as well. You also have an insane amount of variation of clearances. I think you have between .0015 and .008 which is quite a bit of variation but isn't something you are going to see with the naked eye. If you have a thrust bearing problem it has likely torn the rest of the motor apart before it got to this point. You are going to have some shavings in your oil reguardless. That is the natural wear of the motor not much you can do. There is a point where it becomes excessive. How much are you getting in shavings out of it?
Old May 8, 2006 | 06:39 PM
andereck's Avatar
If the thrust surface is gone you can see it move at the crank. The test can't hurt to try.
Old May 8, 2006 | 06:44 PM
Will there be noises???? Metal can be seen before/after you wipe the dipstick with a towel. Small shavings, but I have seen some flakes.
