cam install questions
Old May 10, 2006 | 09:45 PM
SiRgReg23's Avatar
Temple, TX Resident
Default cam install questions
well i got my gm hot cam in the mail today .... yes i know it isnt a big cam blah blah but its what i want for now ..... i have a few questions before i install it on friday ...... it has yellow looking grease between some of the lobes ... do i need to clean that off .. also i noticed its got some debris on it and inside it ... how can i clean that off ..also it came with shims ... do i need to use them .....thanks
Old May 10, 2006 | 09:49 PM
Murdock's Avatar
I used to run a hotcam. I did not use the supplied rocker seat shims, they should be the same as the shims under your current springs.
I would clean the cam inside and out, get all the debris off (metal shavings I'm guessing?) You can get some engine assembly lube from the auto parts store and lube the cam up, or I just cover it in oil then slide it in.
edit: I'd wipe it down with a towel, then blast it with brake cleaner to cut through any grease and grime.
Old May 10, 2006 | 10:01 PM
SiRgReg23's Avatar
Temple, TX Resident
thanks for the help ........ sorry i have another question ..... how will it run with stock tune ....i have an m6
Old May 11, 2006 | 01:50 PM
BigDaddyBry's Avatar
You should be okay for a while on your stock tune. I have it in an A4 and it stalled at every stop before the tune.
