broken valve spring. questions
Old May 13, 2006 | 01:39 AM
bernieblackbird's Avatar
Originally Posted by PREDATOR-Z
From my years of experience, my advice is do not just change 1 spring or 1 valve etc...
Either take the heads off and have them rebuilt.
Or Buy another set of heads. You can get a set of Patriot stage 1 with 918's for $1000, all brand new parts 243 casting (LS2/LS6). They come with gaskets and bolts.
You can then use $199 for a new set of lifters and do all the work yourself.
My thought was to send the head back to Cartek to have them check everything out. I dont like te idea that i have to do away with this set of heads. I did buy them in 2001 but they only have about 5,000 miles on them. If it works out cheaper to buy a new set I may just do that as long as i a not loosing power!!!
What wrong with just changing 1 valve???? What is the reason that I cant mix??? This is al all a learnin curve or me. I have allready been conviced that I should change all the springs.
right now as it stands here is were the money s going
921 springs 398.00
spring compressor tool 129.00 or slp 60.00 slp good/bad tool??
seals??? 16.00
head gasket drivers 30.00
head bolt kit 25.00
1 intake valve ?????????
air fitting for spark plug w/gauge
TOTAL app. $620.00
Old May 13, 2006 | 01:50 AM
cantdrv65's Avatar
Post
921 springs 398.00
seals??? 16.00
head bolt kit 25.00
TOTAL app. $620.00
Sure you can change just one valve.... Dont spend more money than you have to. If none of the others touched the pistons they will be absolutely fine. Perform a leakdown on each cylinder before pulling the head. If all match (and are less than say 15%-20%) except for the bad cylinder...change the springs and repair the damaged valve/guide and you are ready to rock.
Old May 13, 2006 | 02:12 AM
leakdown all the rest of cylinders are good accordng to the mechanic
I believe he siad app 130 or something like that.
still weighin all options though what ever makes more sense. I wiil do
Just have to find tools and read about
I checked out LS1 how to's thanks sounds pretty straight foward
Old May 13, 2006 | 02:16 AM
Jimmy P's Avatar
How did you first know that there was a problem in the first place? Was it idling like crap, wouldn't start?
Old May 13, 2006 | 03:04 AM
PREDATOR-Z's Avatar
2001 is a long time ago, CNC programs have evolved tremendeously.
In general, todays CNC heads flow better than hand ported heads.
Nothing is wrong with changing 1 valve, I was talking about springs.
Trick is, bent valve requires spec check on guide. From my experience, it is better changing the guide in order not to chance problems.
Change of valve requires valve job (on seat and valve)
921 springs 398.00
seals??? 16.00
head bolt kit 25.00
TOTAL app. $620.00
Add fluids, water pump gasket, sealant, valve cover gasket, shipping head (back and forth), valve job labor, guide job, spring seats and retainers (unless they come with springs).
There is no need for air fitting, you can do the TDC method. It is safer and requires no special tools.
My guesstimate is you'll be over $1000 by the time you're done.
Old May 13, 2006 | 03:33 AM
cantdrv65's Avatar
Thumbs up
I might add I wouldnt ship the head back to Cartek. Any local competant engine machine shop should be able to fix you up. If they charge too much just order a new set of CNCd heads like Predator has suggested. Thats what I did, but I bent 10 valves.. I still sold my ls6 cores for 300 bucks. In the end we are just trying to save you money, tally it all up and make your decision.
Old May 13, 2006 | 11:09 AM
I here ya I will deff. I have to way all the options and man the heads are are a lot cheaper than they were in 2001. I will also like to compare flow charts against the Patriot heads from what I have now. And more important also are the springs any good in the patriot head?????
Old May 13, 2006 | 11:16 AM
I do have a local engine shop. I will find out hat they charge for the valve job & valve seat check.
The thing that pisses me off is that a stupid spring cost me so much. That it might be just as exspensive to by a new set of heads.
Anyone bought patriot heads before?????
Just wanted to say thanks to all the help so far this forum rules
Old May 13, 2006 | 11:25 AM
Here is my senario took my car to pik up a few things. Noticed my car was runnig low on gas so i put Mobil 91 octane inthe car. I usally use Sonoco 93, but because was really low on gas I put in Mobil 5 miles later I pull in to my driveway and my car sarts to sound like its running on 4 cylinders and has a extream knock. The car stalls. I try to get it running again but continues to just shut off and wont idle. I changed all the plugs in the car today wich were tr55,s and replaced them with new tr55 and new wires. Tryed to start the car again and still the same results wont idle sound absolutly terrible. There i no SES light the car has only 18,000 miles on it and /app. 5,000 since the head and cam package
Old May 13, 2006 | 12:08 PM
Red99C5's Avatar
If you have a broken single valve spring, then you should not be running the motor. And you need to pull the head off to see what kind of piston and possible cylinder was damage you may have. I hope you have forged pistons.
Also you should check the bent valve, valve guide boss for cracks too. And check that pushrod and lifter.
