Cam Help???
Old May 13, 2006 | 04:47 PM
orangeirocz28's Avatar
Default Cam Help???
Im installing an MTI B1 cam, 114 lobe sep, +4 What should the intake lobe centerline be set at. If its ground on +4, would it be 110?
Old May 13, 2006 | 06:49 PM
2000TransAmWS6's Avatar
ttt for a good guy
Old May 13, 2006 | 08:10 PM
SideStep's Avatar
Just install it straight up... if you wanted to rev it a little higher retard it 2 degrees... (which would give you an ICL of 112)
LSA - Advance = ICL
114 - 4 = 110
