Strating Engine in Wrecked Car
Old May 13, 2006 | 06:20 PM
JLPClassics's Avatar
Default Strating Engine in Wrecked Car
Hello:
I purchased a wrecked 2004 GTO (front end collision). Both airbags deployed. When I try to start the engine, it appears as if I do not have fuel pressure. When the key is on the ‘on’ position, the instrument cluster shows an Airbag, ABS, and Fuel Gauge error and says to contact the dealer. Is there a way to start the engine without repairing the airbags and ABS? Perhaps some sort of fuel pump reset procedure?
Thanks.
Jeff
Old May 13, 2006 | 06:33 PM
conundrum07's Avatar
If you know the pump isnt powered, you could always wire it directly to the battery.
Old May 14, 2006 | 05:49 AM
Viper's Avatar
I would think a friend from a stealership with a TechII could clear the codes. I'm assuming the PCM won't let it start till you at least clear the airbags. Assuming...
