what head and cam combo on a 427 ls6 block?
With my first cam in the 427 I had MTI's Z1 (236/236 .585/.585 112lsa). I made like 530rwhp and 512rwtq.
With the MTI S1 cam (244/244 .612/.612 112lsa) I picked up alot across the board, I made 545rwhp and 520rwtq.
Both cams that I have had are baby cam's for these 427 motors, I could have gone even bigger then the S1 cam, but I don't need it nor want it. I like the way it drives around the streets, very mild mannered with a great idle.
Here is the dyno:
BTW- Thanks MTI!!!
Peace,
Craig.
a Patriot stage 3 setup of some sort should work fine, but what kind/style of pistons did you go with?
The heads will(hopefully) be Warhawk LS7x heads that flow pretty well with stainless valves, so no radical lift and crazy lobe profile cams. No plans for N20 or FI either. Street driven.
