View Poll Results: Should i change my lifters
Naw the stock ones are fine
79.55%
Yeah swap them out for ls7 lifters
20.45%
Voters: 44. You may not vote on this poll
POLL::: change lifters or not change lifters
Old May 15, 2006 | 08:12 PM
killaz's Avatar
Default POLL::: change lifters or not change lifters
If you guys were me. 2000c5 about to do a cam, car has 50,000MILES on it now. I was not planing on taking the heads off, but will if i "NEED" to change the lifters.
THX
Old May 15, 2006 | 08:19 PM
TAQuickness's Avatar
if you are going to go thru the effort of swapping lifters, i'd go with Morels
Old May 15, 2006 | 08:20 PM
jermzz's Avatar
Hell no I wouldn't take my heads off just to change my lifters. my car had 90k heads and cam on stock lifters and it was just fine.
if you're planning on doing heads, then change them while they're off, but it's way too much work to take the heads off just to change them. Besides, it works the oposite way. If you're changing your heads, its minimal work to change a cam at the same time, not vice versa.
Btu hey, if you wanna do it, go ahead!! I'd say buy some nice AFRs at the same time!
Old May 15, 2006 | 08:28 PM
Quik's Avatar
as long as they are in good shape i wouldnt. but there is always a chance you get it together and have to tear it down agai ncause of the lifters.
i run LS7 lifters personally
Old May 15, 2006 | 08:30 PM
777's Avatar
777
Had 105k miles on my car before I changed my stock lifters. Had already been through 3 different cams. Ended up changing them for piece of mind and they looked fine.
Old May 15, 2006 | 08:44 PM
cyphur's Avatar
changed mine @ 78k miles. put comp 850-16s in there. cheap piece of mind.
Old May 15, 2006 | 08:45 PM
fast98's Avatar
still on stock lifters here
Old May 15, 2006 | 08:46 PM
cantdrv65's Avatar
Post
Id stay with the STOCKERS! I changed heads and STILL stayed with mine...all is well.
70Stang's Avatar
I had a lifter collapse with 74k on the clock...stock cam.
I wouldn't do it, but budget to do it if they do infact fail.
Old May 15, 2006 | 08:54 PM
mike c.'s Avatar
if you're going to tear off the heads,you might as well get you a set of ported ones. i would'nt take off the heads just for a lifter swap. 50,000 miles is fine.
Old May 15, 2006 | 09:53 PM
ssbodyman's Avatar
Just did heads/cam/headers/roller rockers and alot more. I spent too much money already and stayed with the stockers and all is fine so far. I am at 50,000 miles so figured they would be fine.
Old May 16, 2006 | 03:45 AM
just-a-z's Avatar
I think you'll be ok with the stock ones.
Old May 16, 2006 | 08:49 AM
GuitsBoy's Avatar
Keep the stockers. If a new cam is going to chew up the old lifters, it would chew up new ones just as easily.
Old May 16, 2006 | 12:32 PM
SVT THIS's Avatar
I'd do the stockers if you must replace them, but I think you're fine with 50k miles.
Old May 16, 2006 | 12:37 PM
indyboom's Avatar
whats so good about ls7 lifters? they fit?
Old May 16, 2006 | 02:54 PM
Quik's Avatar
they are good for higher lift, and yes they fit i run them like i spoke already
Old May 16, 2006 | 03:38 PM
silverlt1ss's Avatar
i heard 98-99 cars had weaker lifters in them. i don't know if thats true or not. about half the people i've talked to had to tear down there heads because of a collasped lifter after a cam swap. but i agree w/Quick on this one
Old May 16, 2006 | 04:53 PM
Quik's Avatar
yep and i do recall you seen a motor that needed torn down cause of abad lifter :cough::cough::cough: mine :cough:
Old May 17, 2006 | 05:02 PM
^^^yes i do
Old May 19, 2006 | 03:52 PM
Cstraub's Avatar
The Ls1 and Ls7 use the same exact same lifter. Absolutely no difference in them. That is straight from an Eaton source.
