Quick ? about 2001 Vette cam
Old May 16, 2006 | 10:53 PM
jasycz28's Avatar
Default Quick ? about 2001 Vette cam
Is there a difference between a 98 Camaro LS1 cam and a 01 Vette LS1 cam. I thought the 01 was a LS6 cam. If so how much of a HP gain can I expect? 30HP? Thanks in advance.
Joshua
Old May 16, 2006 | 10:56 PM
Gold Z's Avatar
The standard 01 Vette cam is NOT the same as a LS6 cam. While the specs may vary very slightly it is basically the same as your stock cam in your 98 LS1. You can expect zero horsepower gain.
Old May 17, 2006 | 04:46 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I don't know if you can pick up 30. Maybe 15 and depending on other mods.
Old May 17, 2006 | 05:44 AM
jasycz28's Avatar
Cool thanks guys
Old May 17, 2006 | 09:38 AM
Aegnor's Avatar
https://ls1tech.com/forums/showpost....87&postcount=9
Old May 17, 2006 | 03:54 PM
Gold Z's Avatar
Huh! Would you please explain how he can pick up 15 hp when the cam specs are almost identical?
Old May 17, 2006 | 04:05 PM
WickedC5's Avatar
why would you even consider a stock cam from another vette? an intake would give you more of a sotp difference. look at something in the 224 range atleast.
