What pistons for 4" stroke?
Old Jan 20, 2003 | 11:13 PM
1bad2k2ta's Avatar
Default What pistons for 4" stroke?
I want to use a 4" stroker crank and a 6.125 rod. Would it be necessary to use a dished piston to maintain stock compression ratio?
How much dish?
I will be supercharging and already have TEA FI heads on the way. Supposed to lower compression from 10.25 to 9.5. Is additional dish desirable if I want to be able set back up to stock later?
Thanks,
Old Jan 21, 2003 | 11:43 AM
ibjamin's Avatar
Default Re: What pistons for 4" stroke?
The Lunati kit can come with pistons that have a -8cc dish that is supposed to give you the stock compression ratio.
There is a set of these Lunati's for sale in this classifieds and also on e-bay right now.
George E.
Old Jan 21, 2003 | 05:49 PM
1bad2k2ta's Avatar
Thanks, George. Any idea what my comp ratio would be if I were to stay with flat top pistons and heads with 73cc chambers?
Old Jan 21, 2003 | 07:03 PM
ibjamin's Avatar
Here's a nice calculator.
http://www.csgnetwork.com/compcalc.html
Using 3.9 bore, 4" stroke, no dish, .054 head gasket, .006 piston above deck, 73cc chamber gives 10.5 to 1 compression.
Using those Lunati -8cc pistons gives you 9.7 to 1
HTH
George
Old Jan 21, 2003 | 07:09 PM
1bad2k2ta's Avatar
George, You da heat! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I am watching the ones on ebay; even closer now. Thanks for the info.
Old Jan 21, 2003 | 08:55 PM
theblur98ss's Avatar
I've got that exact set for sale if you're interested. $300
Old Jan 21, 2003 | 10:18 PM
1bad2k2ta's Avatar
I want them. Does the $300 include shipping?
Thanks
