OK whats the latest on Rockers..
Old May 19, 2006 | 05:42 PM
SAM98WS6's Avatar
Default OK whats the latest on Rockers..
I see the stock rockers are failing as usual all over the place and I wasnt going to worry about it but I dont think I can let that stock **** on my car. Bad enough they are on my Avalanche too.
On a stock car...besides Nasty Nates upgrade rockers..what are the other options? How about those Crane Poly-something. Lightweight, full roller, non-adjustable, no valvecover machining...am I asking too much? 2006 and no aftermarket choice? Im asking..
Old May 19, 2006 | 07:41 PM
mrr23's Avatar
the crane polymatrix rockers are shaft rockers. major modifying to the heads and need for valve cover spacers. http://www.vincihighperformance.com/...0.HTMLPAGE.htm
Old May 19, 2006 | 07:46 PM
SiRgReg23's Avatar
Temple, TX Resident
not trying to hijack the thread ... this is rocker related too .... anyone know where i can get one rocker bolt ..... i actually broke a craftsman socket trying to get one loose .. it didnt round it off much but it did a little when the socket broke free soo i dont want to use that bolt again
Old May 19, 2006 | 08:43 PM
SAM98WS6's Avatar
I guess Harland Sharp 1.7 non-adjustable are the best option...anyone have an opinion on them?
A dealer is the only place to get that bolt but im sure there are zillions laying around in garages and shops if someone can hook you up.
Old May 19, 2006 | 09:19 PM
DanZ28's Avatar
Harland sharp and yella terra's are the only two I know that are priced somewhat reasonable and need no mod's to make them fit. Nasty's are a good option!
Dan
Old May 19, 2006 | 10:19 PM
heavymetals's Avatar
Check out the Comp Cams #1500 system.
Old May 19, 2006 | 10:43 PM
pla-tym's Avatar
any GM parts dealership has them. they're cheap... buy extra's
Old May 20, 2006 | 05:59 AM
Viper's Avatar
Sam
I thought you were using Comp Pro Magnums??
Old May 20, 2006 | 08:32 AM
Byter's Avatar
I love my Crane Race Golds. I tried the Harland Sharps but they required major grinding to get them to fit in my AFR heads. I've taken off the Crane's and put them back on at least 3 dozen times and still they look brand new (as well as the adjusting nuts and lock screws). As a matter of fact, I have a set of 1.8's for sale for less than half price with nuts and screw (no studs or guidplates).
Old May 20, 2006 | 08:46 AM
SAM98WS6's Avatar
My TA had Pro magnums...and they worked great...but you have to clearance the valvecovers and adjust them....Im looking for a stock upgrade for my C5 and Ave. Just piece of mind I never have to see needle bearings on my oil drain plug like I did with the TA...reason I went to the 383. I bet Ive personally seen at least a hundred cases of the stock rockers failing...and im not looking for it.
I guess im getting lazy.
Old May 20, 2006 | 08:48 AM
SAM98WS6's Avatar
I will check it out...thanks
Do you like the maggie??? Funny seeing it on two vehicles in your sig...
Old May 20, 2006 | 08:55 AM
SAM98WS6's Avatar
I looked everywhere for the Comp Cams 1500 system and found nothing...can I get some help?
Old May 20, 2006 | 09:27 AM
USMC Devil Dog's Avatar
Didn't I hear something about the LS7 rockers working in LS1s?
Old May 20, 2006 | 09:44 AM
SAM98WS6's Avatar
Not really...just the exhaust side because of the offset and then i see where there are issues with excess wear on LS1s
Old May 20, 2006 | 01:28 PM
link:
http://www.powerandperformancenews.c...Category_Code=
Yep, addicted to the LS6 and Maggies.
Had to put one on Mr. Vette since the Cad could "keep up" with it.
Also, I have the 1500 system in the Cad, and one sitting on a bench waiting to be put in Mr. Vette.
Old May 20, 2006 | 03:21 PM
Viper's Avatar
Sam
I had Harlan rebuild mine for $250.00, he's a local Cleveland company no less. They look darn stout when you get them back....
