cam help...stalling and surging
Old May 20, 2006 | 10:50 PM
99ccz28's Avatar
Default cam help...stalling and surging
i just had a cam put in with pulley, 3400 stall and headers. i also have 373 gears. the cam is a 224 112. it stalls out at times and surges a lot. the idle is set to 900 rpms. what could be the problem? how could i fix it? thank you
Old May 21, 2006 | 12:15 AM
Doc's Avatar
Doc
Where are you located?
Old May 21, 2006 | 01:39 AM
CASHss99's Avatar
usually on a 112 with an auto it will surge alot try putting the idle to 1k
Old May 21, 2006 | 01:44 AM
Photochop's Avatar
Higher idle and work on the tuning
Old May 21, 2006 | 06:40 AM
98A4LS1's Avatar
Work on the base RAF, VE and timing. Mine idles at 740 rpm, 228 112+1.
Old May 21, 2006 | 09:33 AM
99ccz28's Avatar
i might just have to try and get a tune from tsp...i will call the guy who done the tune and see if he can fix it a little for me thanks everyone oh i am in pennsylvania
