Piston cleaning? in process of h/c install....
Old May 20, 2006 | 11:25 PM
HartAttack's Avatar
Default Piston cleaning? in process of h/c install....
Just curious...What do yall recommended to clean the tops of my pistons while i have the heads off...
here is a picture...
thanks
-Chris
Old May 20, 2006 | 11:36 PM
01red28's Avatar
I turned each piston to TDC and cleaned them with a a plastic scraper and a shop vac because I had to fly cut.
Its OK to clean them up a little
Old May 21, 2006 | 10:55 AM
HartAttack's Avatar
What do you guys recommend to clean it with?
Old May 21, 2006 | 06:27 PM
redtail2426's Avatar
i sprayed mine with a little wd-40 and then scrubbed them lightly with a scotch bright pad,the non scratch one,not the regular ones.The non scratch pads are made of a plastic and work awesome at cleaning the deck surfaces too.
Old May 21, 2006 | 06:51 PM
GuitsBoy's Avatar
I clean mine with some acetone and a plastic sponge. Works great for cleaning old gasket off the heads and block too.
Old May 21, 2006 | 07:11 PM
HartAttack's Avatar
Right on.... i will have to try that out.
thanks alot fella's!
