Looking at different cams for DART 205s
Considering your 'hypothetical' discussion is based on building a trully stock looking stealth package... why not go with a GM casting CNC'ed head? This way your car will look stock under the hood, even to the trained eye...
Stock CNC head wont give the same power as the DART head.
The Darts are only 1200 bucks complete as well.
Discussion centers around making lots of power but having great (better than stock) average torque and HP through the whole curve. Fully emissions legal etc.
The contentious issue for me is EVO and its affect on torque production and also DCR's upper limit on 91 octane
Some say 8.5 is the max, others go as high as 8.8 DCR.
It's not about tricking someone it's about maximizing average hp and tq while keeping stock manifolds/exhaust, a reasonable shiftpoint (~6000-6100rpm) and better than stock drivability.
Some say 8.5 is the max, others go as high as 8.8 DCR.It's not about tricking someone it's about maximizing average hp and tq while keeping stock manifolds/exhaust, a reasonable shiftpoint (~6000-6100rpm) and better than stock drivability.
I want to know the same. I'd like the same shift point with the torque output but what do headers change as far as the EVO
On stock cubes 44>46 EVO means great low>midrange trq
47>50 good low>midrange put power range is shifting higher in rpms
above 50 is low trq in low>midrange output. Trq comes on later in rpms.
Originally Posted by PREDATOR-Z
With regards to DCR, 8.5 with 91 octane and 8.7 with 93/94, that is with a good tune.
Could we get a similar "rule of thumb" for overlap? Interval and affects on curve profiles? Application is LSx with full exhaust.
Ben T.
Sorry for the sidetrack...
What EVO would you suggest for stock mani's and maximum torque production?
I want to maintain power well after peak.
Originally Posted by Studytime
Prdator-Z,
Ben T.
Ben T.
You cannot say 110 lsa or 20* overlap will make power there and not here.
The VE's and durations will dictate that.
There are alot of very strong curves with the afr 205 - 224-228 cams. Since the Darts are cast 205's should be similiar. They wont idle as good enough for you plan i dont think. That new bad *** lift cam Patricks is ground on would be cool but use less duration or widen lsa perhaps to smooth out.
Originally Posted by 2c5s
Comp XFI lobes
268/218
274/224
41' ABDC
48' BBDC
-7 overlap
8.58 SCR
114+2
268/218
274/224
41' ABDC
48' BBDC
-7 overlap
8.58 SCR
114+2
good midrange trq
I prefer 218/224 113+0
42>IVC=6200 rpm peak
45>EVO= more trq in midrange
Comp XFI lobes
268/218
274/224
41' ABDC
48' BBDC
-7 overlap
8.58 SCR
114+2
268/218
274/224
41' ABDC
48' BBDC
-7 overlap
8.58 SCR
114+2
I am using stock manifolds. Those cams are great with headers but I need to maintain -5 to -10 degrees overlap.
6100 rpm peak
good midrange trq
good midrange trq
