ET Performance heads
Old May 25, 2006 | 10:42 PM
SLPSS01's Avatar
Default ET Performance heads
anyone here running a set of ET Performance heads ? Specifically the 215cc version.
http://www.ls1speed.com/catagory.cfm...in%20/%20Heads
Old May 26, 2006 | 07:31 AM
SVT THIS's Avatar
a guy on here named SlickVert is. He's running them with a TRex and a complete setup to accompany it. I believe he is in the 10s full weight
Old May 26, 2006 | 08:22 AM
darrensls1's Avatar
Those are the exact heads I ordered. Still waiting for them to arrive but it shouldn't be much longer
From all the research I did on heads the conclusion I came to was these are the best heads for a stock bottom end LS1. They look fantastic and should slightly outflow AFR205's! I highly recommend these heads if money and time are not an issue (takes a few months to get them).
Old May 26, 2006 | 08:23 AM
CNB's Avatar
CNB
Right here.
Old May 26, 2006 | 09:26 AM
mr2guru's Avatar
I wouldn't get the 977 springs if they are still shipping with them. Although I haven't even ran my set yet, I've seen enough complaints about them on here to go ahead and swap them out.
Old May 26, 2006 | 12:15 PM
Fireball's Avatar
According to craig @ et, they aren't using the 977s anymore.
spec out the crane 99893 springs...thats what I have in my 225s
Old May 27, 2006 | 02:31 PM
SLPSS01's Avatar
How do these heads compare to a set of Patriot LS6 stage 2 heads which are about a grand less ?
Looking at flow numbers while the ET's outflow the Patriots on the intake, the Patriots actually outflow the ET's on the exhaust. I assume the slightly larger intake valve on the ET's (.020") is where the bigger flow numbers are coming from on that side. Is there more to a good set of heads besides flow numbers ?
Old May 27, 2006 | 03:52 PM
pianoprodigy's Avatar
I'm going to be running ETP 215s in my FD with a G5X3 on a 112.
 Michael S. Palmer
Old May 27, 2006 | 11:02 PM
Cary@Perf-Induction's Avatar
Collections Hold
Default flow numbers
Yes, there is a lot more too it than flow numbers,though it is a very easy numerical comparison, it does not seperate one head from another. Take two heads that flow very close to the same and one makes 40-60 more hp. I see it all the time. the 11 degree valve angle and moved valve centerlines allow for a much more efficient fill of the cylinder. The spark plug location, etc. Our flow numbers posted are without a pipe. They are much higher with a pipe.
Old May 27, 2006 | 11:06 PM
beardWS6's Avatar
My ET 245`s flow crazy. Just wish they had a affordable intake to keep up with them!!!
Old May 28, 2006 | 07:59 AM
White_Hawk's Avatar
There was a 383 vette on the dyno at my local shop with a mild cam and 215's. The thing put down 475 on a Mustang dyno. It made a believer out of me as far as the heads go. That thing was sick, and it sounded almost stock.
-Geoff
Old May 28, 2006 | 08:07 PM
Zymosis's Avatar
Boy if that isnt the truth...
