Is it possible to change a piston without removing the motor from the car?
Old Jan 21, 2003 | 09:59 AM
jrios's Avatar
Default Is it possible to change a piston without removing the motor from the car?
Is it possible to remove the oil pan without pulling the motor? If so what has to be done? I broke a ringlands on one cylinder and I don’t want to pull the motor if I don’t have to.
Thanks in advance
Old Jan 21, 2003 | 10:07 AM
Fireball's Avatar
Default Re: Is it possible to change a piston without removing the motor from the car?
dealing with the frustration of having the motor in the car will be a PITA. Pulling the motor is relatively easy on these cars <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
PUll the intake and it'll come from the top <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Besides if its one of the back pistons...it'll probably be a bear to do.
Old Jan 21, 2003 | 10:50 AM
jrios's Avatar
I just installed the new motor about a month ago and I really didn't want to pull it again.
Old Jan 21, 2003 | 09:06 PM
wrencher's Avatar
wrencher
Sounds like something that should also get associated parts/areas well inspected.I wouldn't want to half-@ss it & take the chance.
Old Jan 22, 2003 | 11:29 AM
jrios's Avatar
Well, I did a compression check last night and now I am not sure if it is a ringlands because it ranged from 185 to 190 for all the cylinders. Any suggestions?
Old Jan 22, 2003 | 11:34 AM
Fireball's Avatar
you never gave any symptoms <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" />
Old Jan 22, 2003 | 11:46 AM
jrios's Avatar
The symptoms are very small amount of smoke like a smokestacks puffing out the oil filler hole. Condensation under the oil cap.
Old Jan 22, 2003 | 01:07 PM
jrios's Avatar
does the piston have to be at TDC?
Old Jan 22, 2003 | 02:49 PM
strokedls1's Avatar
No, you want the valves to be closed when you do this. Just pull the valve covers so you can see the valves are closed.
Old Jan 22, 2003 | 03:21 PM
jrios's Avatar
cool thanks
Old Jan 23, 2003 | 12:34 AM
Fireball's Avatar
leak down test it
Old Jan 23, 2003 | 12:37 AM
jrios's Avatar
This maybe a stupid question but how do you do a leak down test?
Old Jan 23, 2003 | 12:49 AM
Fireball's Avatar
with an air compressor and leakdown gage...you supply a constant pressure and the gage measures how much air is leaking from the combustion chamber. If significant air is leaking...listen to where it is coming from.
Bubbles in coolant = blown headgasket
air in the crankcase = bad rings
air in the intake = burnt intake valve
air in the exhuast = burnt exhaust valve
etc
