Help Identify LS6 versus LS2 heads
Old May 27, 2006 | 06:37 PM
w02ramair's Avatar
Default Help Identify LS6 versus LS2 heads
Ok these are 243 castings but I am wondering if there is a way to tell the difference between the LS6 version and the LS2 version. Are they springs yellow on the LS2 version or no?
Old May 27, 2006 | 06:42 PM
Quik's Avatar
no way same casting unless you flip it over and it says the year. my heads are 04 castings.
really doesnt matter both are same except for lighter valves. and you can now also find 243 on a GXP
Old May 27, 2006 | 06:45 PM
davered00ss's Avatar
Moderator
The only difference is the valves. The ls2 valves have white and orange dots on them.
Old May 27, 2006 | 06:49 PM
w02ramair's Avatar
like this?
Old May 28, 2006 | 06:41 AM
PREDATOR-Z's Avatar
Yeap.
Old May 28, 2006 | 07:15 AM
Moderator
Yes, those are ls2 heads.
Old Aug 2, 2006 | 12:39 PM
muncie21's Avatar
Anyone know what heads these are? Notice the exhaust port is round rather than "D" shaped.
Old Aug 2, 2006 | 03:27 PM
02ZOh6's Avatar
I believe those are LS2 heads also. LS6 have a D-shaped exhaust port. Someone should confirm this though.
Old Aug 2, 2006 | 03:30 PM
MrDude_1's Avatar
thats a 243 casting... you can tell by the 243 cast into it. lol.
thats whats stock on my 02 LS1
Old Aug 2, 2006 | 03:37 PM
02ZOh6's Avatar
The LS2 say 243 also. I don't think you can tell the difference that way. I do believe the exhaust ports are different though.
Old Aug 2, 2006 | 03:39 PM
02ZOh6's Avatar
I just pulled my 02 Z06 heads out of their boxes and they have D-shaped ports. Those ain't LS6 heads.
Old Aug 2, 2006 | 03:43 PM
MrDude_1's Avatar
thats because.......
..... they're the same head.
its still a 243 casting. GM is allowed to use the same casting on more then one engine RPO...
Old Aug 2, 2006 | 04:06 PM
muncie21's Avatar
I've been told that LS6 243 heads have D shaped exhaust ports and LS1 (241's) have round ones. I posted a picture of a round port head with 243 casting numbers on it. Looking to see what head it really is.
Old Aug 2, 2006 | 04:13 PM
02ZOh6's Avatar
Technically no. The exhaust ports are different (the gaskets also), so they're not exactly the same head, I'm too lazy to take a pic of mine but it's obvious. Also as others have pointed out they don't have the lighter valves that the 02-04 Z06's have. I know they're interchangeable, thanks. I would run either on my Z06, I could care less.
Old Aug 2, 2006 | 04:35 PM
muncie21's Avatar
So............are these LS2 heads? If not, what are they? They came with yellow springs
Old Aug 2, 2006 | 04:43 PM
zigroid's Avatar
http://community.webshots.com/album/552273254iERMPE
there some pictures of my LS2, if that helps at all.
Old Aug 2, 2006 | 04:52 PM
02ZOh6's Avatar
I would bet large $$$ that those are LS2 heads.
Old Aug 2, 2006 | 04:54 PM
Krab's Avatar
Aren't the exhaust ports D shaped on both heads? I mean, they are both 243 castings. I bought some heads off a '05 GTO and they had D shaped exhaust ports from what I could tell. The only difference between the two heads, which has already been mentioned, is the lighter valves on the heads that came off a Z06. Someone correct me if I'm wrong...
Old Aug 2, 2006 | 06:17 PM
Okie5.3's Avatar
the head pictured in the 1st post has D shaped ports as all 243 castings do. my 243s (LS2 vintage) have 'em as well.
Old Aug 2, 2006 | 06:34 PM
redaddiction's Avatar
Originally Posted by w02ramair
like this?
My ls2 heads have that also the painted valves.
