porting the heads
Old May 30, 2006 | 09:06 AM
eLTwerker's Avatar
Default porting the heads
Should I get my stock heads(2002 camaro z28 5.7l ls1 auto) ported or buy ported heads. tsp has ported heads for $1600. Which is better in the hp vs. $$ battle?
Old May 30, 2006 | 10:00 AM
GuitsBoy's Avatar
HP to $$ champions will be the patriot, PRC, or livernois LS6 CNC heads. I believe theyre all under 1000 bucks and flow right around 300 CFM through stock valves. Read reviews and choose the sponsor you like the best.
Old May 30, 2006 | 11:56 AM
Gunnar@Patriot's Avatar
We can do you a set of CNC ported 243 castings with oem 2.00"/1.55" (non-sodium valves) and our Patriot Gold dual springs for $1125.00 shipped to you anywhere in the US. These will also include a set of new, oem head bolts.
