Cam Install Dot Question! - Pic inside
Old May 30, 2006 | 12:47 PM
sh33p4u's Avatar
Default Cam Install Dot Question! - Pic inside
Just wondering if everybody thinks these are lined up pretty good? Thanks!
Attached Thumbnails Cam Install Dot Question! - Pic inside-mini-pict0165.jpg
Old May 30, 2006 | 12:50 PM
iamsickofitall's Avatar
you got it
Old May 30, 2006 | 12:52 PM
00SLPSS's Avatar
looks good, i toyed with mine for a while and realized that the teeth are so big on the gears, even if it looks very slightly off, its all good.
Old May 30, 2006 | 12:55 PM
sh33p4u's Avatar
thanks guys, i'm almost finished!
Old May 30, 2006 | 01:04 PM
Predator's Avatar
Looks good, congrats!!
Old May 30, 2006 | 01:57 PM
chewy99ws6's Avatar
looks good to me.
Old May 30, 2006 | 07:16 PM
shouldaboughttheZ's Avatar
got my vote for good to go
Old May 30, 2006 | 07:18 PM
AdamSS's Avatar
good ! exactly like mine
Old May 30, 2006 | 07:30 PM
waterbug1999's Avatar
You got piston 1 TDC?
Old May 30, 2006 | 07:41 PM
03 BUSA's Avatar
Looks good! Get r done and fire her up!!!
Old May 30, 2006 | 08:04 PM
SSDoubleK's Avatar
Wink
Looks great, wish I would of had mine looking that good the first time.
Old May 30, 2006 | 09:23 PM
REDWS6ROCKET's Avatar
6 and 12 looks good man!
Old May 30, 2006 | 09:36 PM
sh33p4u's Avatar
w00t, thanks for all the replies guys. Tommorow is firing up day!! (if I can get ahold of some pushrods!)
Old May 30, 2006 | 09:52 PM
blkbird's Avatar
Is that important? Just curious...
Old May 30, 2006 | 09:53 PM
CHIWS6's Avatar
yup good to go!!!
Old May 30, 2006 | 10:30 PM
Project GatTagO's Avatar
Only if you don't to bend all your valves...
Andrew
Old May 30, 2006 | 10:48 PM
blkbird's Avatar
Andrew
I guess I got lucky....
Old May 30, 2006 | 10:51 PM
Full-Force's Avatar
guys, quit confusing people
if the dot on the crank gear is at 12:00 then #1 is at TDC
Old May 30, 2006 | 10:54 PM
blkbird's Avatar
Thank you!!!
Old May 30, 2006 | 11:02 PM
1QuickT-A's Avatar
Exactly! The only time you would need to double check this is if the motor was newly rebuilt or something and the crank gear was removed..
