LS6 ported head
Old May 31, 2006 | 11:43 AM
1sickta's Avatar
Default LS6 ported head
how many of you guys having a problem with smoking after head installed?
what did you guys do to fix it ?
i did reseal intake rocker bolt but i still having same problem.
Old May 31, 2006 | 03:10 PM
1sickta's Avatar
no one can help me out ?
help me pleease i'm desperate, i can't go anywhere
or should i returned this head and get new set of heads?
Old May 31, 2006 | 04:31 PM
GuitsBoy's Avatar
What else was done at the same time? What condition are the valve seals in?
Old May 31, 2006 | 04:58 PM
1sickta's Avatar
they swaped Comp Cams 918 Springs when the installed cam for me last month because i bought LS6 head with stock spring.
Old May 31, 2006 | 06:35 PM
davered00ss's Avatar
Moderator
Who ported them?
Old May 31, 2006 | 06:46 PM
2002blackZ's Avatar
Few questions: Where is it smoking from? I'm assuming the exhaust, but it's best to make sure. What color of smoke? Did you install them yourself? If so, did you make sure you cleaned the top of the block really well?
Old May 31, 2006 | 07:10 PM
1sickta's Avatar
Originally Posted by davered00ss
Who ported them?
TSP did
Old May 31, 2006 | 07:12 PM
1sickta's Avatar
from exhaust and its blue smoke , Don Lee installed for me.
Old May 31, 2006 | 10:15 PM
2002blackZ's Avatar
so it is oil. I would say Guitsboy is on the right track with the valve seals.
You're dipstick isn't poping out is it?
https://ls1tech.com/forums/showthrea...ghlight=blowby
You may want to check this thread and do this test to make sure.
You can pull your spark plugs and that might help you determine which cylinder is burning the oil. (if it's burning a lot I guess)
About the only other thing I can think of would be a bad head gasket.
Good luck! Let us know what you find.
