running AC and a cam??
Old Jun 1, 2006 | 05:28 PM
monkey11's Avatar
Default running AC and a cam??
i've had a TQ 2 cam from TSP for a while now, i was just trying to find out, what i need to do to be able to use the car's AC? i dont have a tune yet, but what exactly in the tune do i adjust for AC? and is there anything eles i can do, what do you guys out there with cammed up cars do with the AC? i already dont use the AC it just for the few times that i do.i can only use it when im on the highway, not stop and go traffic or the car will die. any info would help?
Old Jun 1, 2006 | 05:52 PM
vodas00ss's Avatar
i run the magic stick and I have no problems with running my ac. The only time it has a problem is when I start the car and I forgot to turn the ac off, it has a little trouble tryin to find idle, but I just turn it off.
Old Jun 1, 2006 | 08:33 PM
GuitsBoy's Avatar
You have to bump up the max idle air offset. Its an idle trim that automatically measures how much extra air is required when you have the a/c on. Stock, its limited to .50 g/s. I bumped mine up to 2.0 and havnt once it learned itself out, i havnt had any trouble. Make sure youve got your RAF inline first.
