7 Heat Range Plug???
Old Jun 2, 2006 | 02:47 PM
DAPSUPRSLO's Avatar
Default 7 Heat Range Plug???
Does anyone know of a spark plug in the 7 heat range designed for the ls1, actually c5r heads, motors. Tr55 ngk has a 14mm thread size, is tapered, 5/8" wrench diameter, and .708" reach so these are the specs i'm looking for. Thanks.
P.S. It's for my 434" c5r headed 11.5 to 1 darton sleeved ls1. Projected n/a hp is around 700 fly wheel, thanks.
Old Jun 2, 2006 | 03:07 PM
Mike@TEA's Avatar
ngk lists a # BP7EFS OR STOCK #3526 it appears the tip is not extended as far as the tr55-tr6. that also crosses to an autolite 103.
Old Jun 2, 2006 | 03:12 PM
DAPSUPRSLO's Avatar
So would the tip not extending as far be a problem? I'd imagine the ls1 heads and c5r heads require the same demension plug.
Old Jun 2, 2006 | 03:25 PM
DAPSUPRSLO's Avatar
Actually, it's got the exact dimensions I need. Now the question is where can I get it by tomorow, probably no where, ha. Thanks though!!!
Old Jun 2, 2006 | 03:37 PM
Beast96Z's Avatar
If your going N/A, why are you looking in the 7 heat range? I planned on 6's in my 11:8:1 N/A 454. 7's are for big No2 app's.
Old Jun 2, 2006 | 04:45 PM
DAPSUPRSLO's Avatar
Was suggested to me by Erik of HPE, builder of my shortblock. If they are too cold i'll try a 6 range.
