what heads?
Old Jun 5, 2006 | 01:26 AM
dustin99a4's Avatar
Default what heads?
i am wanting to do a cam change possibly a t-rex but on a higher lsa for nitrous and i was wondering which heads would work better with a mild port job
241s
of 5.3s
does any one have and dyno numbers with either of these combos
thanks dustin
Old Jun 5, 2006 | 02:30 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You can run the t-rex with nitrous as is from thunder on the 109-110 LSA. It is quite fond of it actually. Their posterboy was gonna run the t-rex with a shot on top of it. Plus you don't need a higher LSA unless you plan on running like a 200+ direct port shot.
Old Jun 5, 2006 | 02:31 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
And as far as heads go. I would do the 5.3's. Nitrous likes a bit higher CR motor.
Old Jun 5, 2006 | 11:22 AM
allngn_c5's Avatar
AFR 205's w/59 cc A little pricey
Old Jun 5, 2006 | 06:07 PM
SVT THIS's Avatar
If money ain't a thing-ET 215's. On a budget, TSP LS6 heads.
Old Jun 6, 2006 | 02:46 AM
dustin99a4's Avatar
thanks for the sugestions
how much will the 5.3s bump up the compression
Old Jun 6, 2006 | 02:47 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
10.8:1 most likely. Also a tough question to answer due to CC sizes and milling will change the entire DCR.
