gaskets
Old Jun 6, 2006 | 10:33 PM
viewsonic's Avatar
Default gaskets
How do you guys feel about reusing oem head gaskets for a head swap?
2K miles on the gaskets. Figured it may be good to save some money....
Old Jun 6, 2006 | 10:37 PM
SSRZ28's Avatar
why risk it. gaskets are cheap
Old Jun 6, 2006 | 10:38 PM
Beast96Z's Avatar
Stock gaskets are only $25 bucks from the dealer. Never reuse a gasket unless they are intended for that purpose, and stockers aren't. Once there crushed, there done.
Old Jun 6, 2006 | 10:56 PM
viewsonic's Avatar
So they are one time use? $50 is a decent chunk of change. (a night out)...
So i figured if i could save a few bucks....
Anyone know the cheapest place to buy cometics?
Old Jun 6, 2006 | 11:04 PM
Beast96Z's Avatar
$25 is for the pair. So you still have $25 for beer. Cometics will run you close to $200 bucks about anywere you get them. Haven't seen to many people with deals on them. Not to mention the risk of leaks. I had bad luck with cometics.
Old Jun 6, 2006 | 11:20 PM
viewsonic's Avatar
Where are you buying them for $25 a pair?
GMPARTSDIRECT has them for $25 each...
Gotta a sponsor link? PM me if you can not post a public link to it...
Old Jun 6, 2006 | 11:29 PM
Beast96Z's Avatar
Are you wanting the graphite or the MLS? I believe the MLS's were the cheap ones, although the graphites weren't expensive either. www.sdpc2000.com is probablly going to be the best place. Contacting Mike (bg-sdpc) will net you the best results. Here's his profile: https://ls1tech.com/forums/member.php?u=57241
