PRC heads and G5X3 cam 112LSA
Old Jun 6, 2006 | 10:52 PM
c5_ls1_6spd's Avatar
Default PRC heads and G5X3 cam 112LSA
will the PRC stage 2.5 cnc ls6 heads with 2.04/1.575 valves work with the G5X3 cam on a 112LSA w/o flycutting, w/o milling and using stock gm gaskets?
Old Jun 6, 2006 | 11:18 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Dude, you are going to have to measure yourself. No one on the internet is going to be able to give you a concrete 100% answer of yes or no. But since that is what you are after...I belive that it will fit since you are not messing with clearances involving the deck and what not.
