Stock Rockers ?
Old Jun 7, 2006 | 01:14 PM
CheeseNR7's Avatar
Default Stock Rockers ?
Anybuddy out there know the limitations of the stock rocker arms of an 02 LS1 ..... RPM, Torque, HorsePower?????????????????? any input would be great
thanks
Nick
Old Jun 7, 2006 | 03:44 PM
vettenuts's Avatar
The limitations will more likely be dictated by spring loads, cam size (lift) and max RPM.
Old Jun 8, 2006 | 11:35 AM
CheeseNR7's Avatar
i am running the psi springs rated to .625 lift im not sure on the spring loads and a cam that has a lift around .590, i am planing on max rpm being around 6500-7000 any idea???
Old Jun 8, 2006 | 11:51 AM
DuronClocker's Avatar
I'd imagine they'll be okay. I just fired my new motor up last night for the first time, and I'm running the Patriot Gold springs with a .646" lift cam and very aggressive ramp rates. I'll probably be running the motor up to 6500 or maybe a bit higher. I hope they'll hold up. Patrick G has the same setup with stock rockers and they work fine, though I think his may have been modified.
Old Jun 8, 2006 | 05:24 PM
CheeseNR7's Avatar
ttt......
