CAM Gurus help please!
Can anybody figure out the DCR on a stock bottom end LS-6'd motor, with 64cc heads, and this cam?
| Home | Find a Retailer | Contact |
Products | Technical Help | Product & Company News | HISTORY
Part Number Part name Grind number
BROWSE PRODUCTS
Select Category
Main > Camshafts
Select Application
Main > Vehicle_Type - Auto > Cylinders - 8 > Engine_Make - CHEVROLET > Year - 2002 > Engine_Size - 5.3-5.7-6.0 L
Camshaft Specification Card BACK TO LIST
Part Number: 1449601 Grind Number: HR-228/353-2S1-12 (Z-CAM)
Engine Identification:
Start Yr. End Yr. Make Cyl Description
1997 2005 CHEVROLET 8 Performance cam for cars or trucks, stock or w/mild engine modifications. Use in 5300-5.7-6000 engines. Rough idle, slight chop. Must use 144832-16 valve springs. Auto or manual transmission. Good cam for PowerMax Tuner.
Engine Size Configuration
5.7 L V
Valve Setting: Intake .000 Exhaust .000 HOT
Lift: Intake @Cam 353 @Valve 600 All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 353 @Valve 600
Rocker Arm Ratio 1.70
Cam Timing: TAPPET @.004
Lift: Opens Closes ADV Duration
Intake 34.0 BTDC 76.0 ABDC 290.0 °
Exhaust 80.0 BBDC 34.0 ATDC 294.0 °
Spring Requirements: Triple Dual Outer Inner
Part Number 144832
Loads Closed 112 LBS @ 1.800 or 1 13/16
Open 330 LBS @ 1.200
Recommended RPM range with matching components
Minimum RPM 3500
Maximum RPM 6500
Valve Float 7100
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake 7.0 BTDC 41.0 ABDC 107 228.0 °
Exhaust 53.0 BBDC (1.0) BTDC 117 232.0 °
Remarks:
FIRING ORDER: 1-8-7-2-6-5-4-3
Crane Cams continuously improves and upgrades its cam designs. In some cases this may mean that two Crane Cams with the same part number may actually be different grinds. You must check the GRIND NUMBER stamped on the front of the camshaft and check it against the Grind Number near the top of the Spec Card. For more information on the finest available camshafts, valve train components, and automotive ignition products, visit your local Crane dealer or call the Crane Cams tech line at (386) 258-6174 or FAX (386) 258-6167
install instructions
BROWSE PRODUCTS
Select Category
Main > Camshafts
Select Application
5.7 L V
Part Number 144832
Minimum RPM 3500
Maximum RPM 6500
Valve Float 7100
Remarks:
