Need help between 2 cams quick!
Z06 MAF
Kooks 1 7/8" race headers
Cometic .040" gaskets
Comp 918's
Morel type lifters
No emissions
duals out the back
X-Pipe
30# Ford SVO injectors
25% UD pulley
My delima is between these two cams:
Frutal F11 cam
228/230 duration .577"/.595" lift on 114
or this Comp grind LS1/3404F cam:
232/236 duration .575"/.575" lift on 114 (+4)
I think that the 232/236 cam would be better suited for my setup and produce a little more without loosing any drivablity. Any thoughts? Either some boost or a good set of heads will eventually make their way onto the car. Thanks
Scott
