cutting out
Old Jun 10, 2006 | 05:13 AM
rwb's Avatar
rwb
Default cutting out
My car is cutting out at about 3200 rpms under load. I disconnected the blower(ati p1sc) and then it cuts out at about 3800 rpm's. I've replaced
plugs TR6's gapped at 30
plug wires
O2 sensors front
crank sensor
I checked every connection and my fuel pressure stays at 65 psi where I put it. The car returns no codes so I am now at a loss as what to check. Any ideas???
Old Jun 10, 2006 | 07:55 AM
jub jub's Avatar
Since you changed plugs, I would check wires and then injectors. I had an injector once that just refused to behave and caused the engine to run on 7 cylinders.
It's difficult to diagnose problems over the internet because they're so many variables. Just illiminate them one at a time.
