TEA Trick Flow heads initial impression
Old Jun 15, 2006 | 07:27 AM
JNorris's Avatar
Moderator
Originally Posted by Brian Tooley
I just recieved a phone call from a leading technical editorial writer that tested the TFS heads on Westechs dyno and with changing heads only he saw 52 HP, which he said is the best they have ever seen simply changing the stock heads for aftermarket. It looks to be a very good product with a ton of versitility in the future. I think when you look at the quality, flow, power and bolt on ability it's a hands down winner among the currently available aftermarket heads on a 5.7 engine. This head actually has BETTER geometry and better piston to valve clearance then a stock head as well. There will be a LS2 version available soon as well as a 402-408 version, the latter version will probably have a +.400" raised valve cover rail as well. The best part is there will be practically no wait time on these as well.
Great info Brian.
John
