Flycutting necessary??
Old Jun 13, 2006 | 02:28 PM
SHINER's Avatar
Default Flycutting necessary??
I bought stock LS6 heads, and a TSP Torquer V.2(232/234 .595 .598 on a 112) I called back and said I wanted a +2 advancement on the LSA. Am I gonna have to flycut my pistons?
Old Jun 13, 2006 | 03:08 PM
JakeY2KZ's Avatar
Pretty sure you should have enough clearance. But checking wouldn't hurt either.
Old Jun 13, 2006 | 03:11 PM
GuitsBoy's Avatar
Shouldnt have to. Less advance actually improves piston to valve clearance.
Old Jun 13, 2006 | 03:16 PM
Joel_SS's Avatar
You should have enough clearance that duration is not too much.. that being said it could do no harm to check and get that warn fuzzy felling..
Old Jun 13, 2006 | 04:07 PM
SVT THIS's Avatar
The Trex (242/248 .608/.612 110 lsa) doesn't require flycutting on stock valved unmilled LS6 heads, so I think you'll be fine.
Old Jun 13, 2006 | 04:35 PM
SHINER's Avatar
alright thanks for the input guys
Old Jun 23, 2006 | 10:06 PM
oneBADDz's Avatar
What about with the patriot stage IIs, I was told that with those heads I might have ptv problems with the torquer V2. Any help would be appreciated
