PTV Clearance Question
Old Jun 14, 2006 | 04:51 PM
dalejr8ls1's Avatar
Default PTV Clearance Question
I'm running Dart 205's w/ GM head gaskets and a TR 230 cam w/ 570 lift, will I have any piston to valve clearances if I go with the stock lenth hardened PR's?
Old Jun 14, 2006 | 05:01 PM
Joel_SS's Avatar
Lift is not what you have to worry about with PTV it is duration.. you will be fine with that combo.. put T-rex or something in there then you should be checking.
Old Jun 14, 2006 | 06:09 PM
vettenuts's Avatar
Check it, someone with a smaller cam was close. Not worth finding out the hard way, although I think he had the 225's.
Also, pushrods won't affect PTV, lift and duration will.
