What are the differences between an C5 LS1 and a Fbody LS1?
Old Jun 15, 2006 | 10:59 AM
dsblk93gt's Avatar
Default What are the differences between an C5 LS1 and a Fbody LS1?
What are the REAL differences between the 2? I know the C5 LS1 is rated at higher HP but from everything I had ever read there was no real difference in "actual" power output.
Old Jun 15, 2006 | 11:15 AM
Blue Hawk's Avatar
Only thing I can see is the drive-by-wire throttle body on the C5 LS1 vs cable throttle body on the f-body LS1.
General consensus is that everything else is the same.
https://ls1tech.com/forums/showpost....8&postcount=10
Old Jun 15, 2006 | 12:20 PM
blackbelt's Avatar
from what i understand the cam in fbody is actually slightly larger. (not that you would notice it though. the difference is so small)
Old Jun 15, 2006 | 12:23 PM
Phoenix 2001's Avatar
I heard this as well that it is the camshaft and the air intake but that changed in the 01-02 model F-body which came with the LS6 intake.
Old Jun 15, 2006 | 12:42 PM
GuitsBoy's Avatar
The tune differs a bit...
Old Jun 15, 2006 | 01:46 PM
Joel_SS's Avatar
Oil pan is diffrent..
Old Jun 15, 2006 | 02:08 PM
2000TransAmWS6's Avatar
no EGR on Vettes, not that it makes a power difference
the intake and exhaust probably flow alittle better on the vettes
according to ALLDATA the camshaft lobes on a 2000 OEM Corvette camshafts have .277/.281 lift and on a 2000 OEM Camaro camshaft it is .292/.292 **this is lobe lift not valve lift**
Old Jun 15, 2006 | 02:16 PM
777's Avatar
777
Differences in the engine that I've heard of (most mentioned)
oil pan
throttle body (electric)
intake manifold (no egr provision)
rod bolts (stronger, I believe)
Old Jun 15, 2006 | 03:02 PM
blackbelt's Avatar
rod bolts are stronger on all 01 and newer ls1's f body included
Old Jun 15, 2006 | 03:10 PM
GuitsBoy's Avatar
Yes, infact i hear claims that case as early as late 2000 also got the updated rod bolts. And the update rod bolts were the same wether they were in an f-body ls1 or the c5 z06 ls6 motor. This allowed the LS6 to spin to 6600 from the factory.
