problems...need all possible opinions....? plesae
98 z28
full bolt ons, including gears
best before was 12.5@109.xx
now im running 13.0@102.xx
i know i have lazy 02s. tunner told me.
i need to change plugs/wires
but do you think plugs/wires/02s can cause me almost half a second?
and im only trapping 102? i trapped that when i was stock!
1.68 60 ft. 8.2@81 1/8th.
please give me all opinoins...
traction? 1.68 ft is no the best, but its good.
humid? it was an ok night...not too humid.
any more opinions?
so, you had a 1.68 60 the other night and ran slower....
i would say clutch, but you probably wouldnt be cutting 1.6 60's on a bad clutch, but anything is possible.
Go ahead and do plugs/wires and fuel filter and run again and see if youre still running slower.
Maybe it was just a bad night for you.
12.5@109 is the quickest with a 1.75 60
and my car is auto, sorry, 3400 stall.
night was humid, but others were running good times, where they run normally...i doubt i wuld be the only one affected.
well here is what im going.
new 02 sensors
air fitler (clean)
fuel filter
msd wires
ngk plugs
any other recommendations?
oil is only about 1 month (800-900) old.
before you do the wires, i would get a multimeter and check the ones you have. just to save a lil $ bc i know my MSD wires were like 80 bucks. plugs/fuel filter are cheap and easy.
o2's are a possibility though.
new 02 sensors
air fitler (clean)
fuel filter
msd wires
ngk plugs
have had about 20 passes total on the tranny, 15 on verter.
just because your stuff is relatively new ,suspect everything until you can positively eliminate it as what is causing your problems.Good luck I hope it is something simple.
he has a stockish 00 z a4, lid + ls6 intake + tune and was trapping 107 last year, this year he is trapping 102-103, no changes to anything. the car now has 153k on it, i think...and is eating coolant like a mfer, no smoke, just missing antifreeze.
