One last issue
If thats the case your timing chain is off or you have too much preload, or the base circle of your cam is different than stock.
Try backing your rocker arms out a bit where they are just loose and see if when you crank it over you get compression but dont start it.
But as you stated, you hate to go in there and find out it is not.
Have you doubled check everything else? And the dot to dot is the last thing.
