Bent push rod... Causes?
Old Jun 17, 2006 | 10:42 PM
ls1_chevelle's Avatar
Default Bent push rod... Causes?
Buddy got his 2002 LS1/4l60e into his 72 Chev shorty and its now on the road. The engine/tranny have 10,xxx miles on it.
Last night we were driving around and stared to hear a ticking noise. The truck only saw 5500rpm MAX that night(only night its been out) Before it never ticked in the garage and just going around the block either.
We pulled the valve covers off and the #8 Cylinder, farthest back rocker assembly(can't remember if exhaust or intake) has a bent push rod. We replaced it and put 5 miles on it just to have another ticking...
What I'm wondering is what could be causing this? Some people are mentioning if it has ever had an over rev the valvesprings could be done causing the bent rod? I personally think lifter but who knows? Oh ya, the engine sat for 1.5 years but again, no ticking while in the garage running for 20 minutes, nor when it went around the block a good 6 times(about 10 miles total).
Thanks gang,
-Matt
Old Jun 17, 2006 | 11:47 PM
Havok2's Avatar
isnt it over revving?? rev limiter?
Old Jun 18, 2006 | 11:36 AM
HAMRHEAD's Avatar
I've always thought it was from over reving. If it turns out to be something else post it up incase this happens to anyone else. I've seen it with n2o users a few times too.
Old Jun 18, 2006 | 12:07 PM
Engine only saw 5700rpm MAX. so its not a case of over revving it. Carbon build up on the valve?
-Matt
Old Jun 18, 2006 | 12:18 PM
Studytime's Avatar
The tach might not be reading correctly.
Ben T.
