NEED HELP, ms4 or trex
Originally Posted by 99T/A
You should see some MS4 results in the next couple of weeks from me. I am sure I will be happy with the outcome.
i think he probably made his decision.....
thread was originally started on 06-19-2006, 11:46 PM..
pay attention to this if your going to search for things..
try not to necropost... its annoying to see posts where someone is saying there is no real world numbers from the ms4..
We've done engine dyno comparisons with these camshafts as well as a couple other larger camshafts numerous times. Like I always say I'll put the MS4 up against any camshaft out there. I'm not making these claims because I think something might work better, I've tested the camshafts side by side on the engine dyno many times before.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
