NEW high volume oil pump
I am just a little sketch becasue all I hear about on here are the ported ls6 oil pumps. It is supposed to be a high flow pump of some sort.
Check it out: http://www.sdpc2000.com/catalog/4460...es-Engines.htm
My friend also said there is no need to port, or buy a ported one because they flow just fine out-of-the-box.
Jason
Jason
****. SO much for saving $60 and going with this pump instead of an ls6. H/C swaps blow.....for my wallet at least.
Anyone else actually USE this?
Jason
Jason
But I doubt thats the same one. I couldn't imagine thunder charging over twice as much for the same part.
).He said it is a GM performace part and FINE to use with a stock oil pan....that is what it is designed for.
i've thought about starving the motor for oil due to a pump that works TOO well...so it lead me to searching and reading that it's ok to run the f-bods 1 quart over full to ensure this doesn't happen? evidently some guys that road race (with corvettes, too) have been doing it for awhile. any other input?
sorry dude, not trying to hijack your thread!
We all know the nickel and dime stuff for a H/C swap really starts to add up.
I've got a ported LS6 I can sell you for 70 shipped, was ported by alan futral. CAme out of my shortblock with 58k miles on the shortblock... 4 k on the pump. was making over 50 lbs at idle and a good bit over 60 full.
PM me if you'd like it.
