is this swap worth it in the long run
Old Jun 21, 2006 | 09:23 PM
erikthegoalie's Avatar
Question is this swap worth it in the long run
Ive got a nice set of 5.3L patriot performance heads....not milled or anything exactly how you get em from patriot....
would it be worth the time and effort and some $ to change to say the patriot ls6 style heads??
the car is an 02 SS and is STREET only
Ive got a 225/225 cam right now waiting for install...thinking about going with a Torquer 2 though.....
please chime in....
im divided...
Thanks
Old Jun 21, 2006 | 09:29 PM
brad8266's Avatar
Probably not IMO.
Old Jun 22, 2006 | 12:04 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Possibly. If you had the LS6 heads milled and then a cleanup port job. They would probably end up being far superior to the 5.3 head. Maybe about 10-15 to the ground if you had to put a number to it.
Old Jun 22, 2006 | 09:46 AM
true..
well we shall see what the numbers are...then ill go from there I can always swap em..
