DCR Calulations
Old Jun 22, 2006 | 12:15 PM
dedge's Avatar
Default DCR Calulations
Has anybody done the DCR on a Torquer V2 ground on a 112? My 98 heads really suck and all this talk about finding the best compression has got me wanting some new heads. I only put down 351RHP on the dyno and have been told the heads are killing me. I know a couple of friends who have used aftermarket for sale but I wouldn't want to buy without knowing what CR to shoot for.
Old Jun 22, 2006 | 03:27 PM
conundrum07's Avatar
Open up the spreadsheet in the sticky and punch in your numbers. You should shoot for 8.5-8.8 depending on what octane gas you can get. FWIW when I ran the numbers for a potential setup w/ .040 gaskets it indicated a 62cc head would be needed to make ~8.5:1.
Old Jun 23, 2006 | 05:15 PM
ls2 bait's Avatar
ive been trying to do this and it wont let me since i dont have microsoft office. is there another way to open it?
Old Jun 23, 2006 | 05:32 PM
JZ'sTA's Avatar
Dont even bother Tommy your DCR sucks badly. Is like 7.5 off the top of my head.
You could defentially use some compression.
Old Jun 23, 2006 | 06:41 PM
ls2 bait's Avatar
from what i gather i need to look for like a 58 cc head. this is with the same cam mentioned above.
Old Jun 23, 2006 | 06:55 PM
Tri5Nerd's Avatar
Default Here's my calcs for T2 using ported 5.7L heads
Got this info from guru on this forum for me setup.
Fly cutting is needed to get the compression needed, the chamber size will vary depending on the type of head you're using.
60 cc chambers
.040 gasket
232/234, .595/.598 112+4 LSA
for a 11.05:1 SCR and 8.53 DCR
7.40 p-rods
A big stall (4200+)
This would get me moving pretty well.
Old Jun 23, 2006 | 07:47 PM
ls2 bait's Avatar
ok well we need to come up with something thats not going to involve flycutting pistons. id like to run a set of 5.3's but im not sure above ptv clearance or maybe even the dart 205's. the dart have a larger cumbustion chamber which is going to lower the dcr. i am in desperate need of torque as im sure most are with this cam and stock heads.
