Engine shaking on cammed cars
Does anyone think of poly engine mounts as kind of a band aid and not a real fix per say?
Some of the lessons I've learned is that the best time to do motor mounts is when you have the headers out, at that point, you are looking at 5 minutes of work to swap both.
Just to dispell the myth with poly motor mounts, NO, they won't make the car unpleasant to drive. Once they settle in, there is no difference in driveline feel. Since the motor isn't shaking anymore, you actually reduce the feel of the vibration since you no long have that 350lb of motor, and 120lb of transmission shaking the whole car.
To recap: DO IT, INSTALL POLY MOTOR MOUNTS AS ONE OF THE FIRST MODS YOU DO.
