Oil pumps
Old Jun 23, 2006 | 09:03 AM
YEV33's Avatar
Default Oil pumps
I am planning on doing a cam and springs on my LS1, at the same time I am looking to change my timing chain and my oil pump. I will be using the stock oil pan, what should I replace my stock pump with? I think that my stock pump is an LS6 pump not exactly sure. I figure with the car having 72,000 miles it might not be a bad idea to do it.
Old Jun 23, 2006 | 09:30 AM
HAMRHEAD's Avatar
Just replace it with another LS6 pump or like the SLP ported oil pump. No need for anything to fancy unless you want to go to a dry sump system. $$$$$$
Old Jun 23, 2006 | 09:45 AM
ninobrn99's Avatar
Ive learned from others not to get SLP With your mods a factory ls6 will do fine. If you want a ported one, price it out through the other sponsors.
