what size cam with 1.85 rockers???
Old Jun 28, 2006 | 10:58 PM
heymoej's Avatar
Default what is the largest cam i can do with 1.85 rockers???
i recently had comp cams 1.85 rockers,918 springs & ty retainers installed on my bolt on only 2000 m6 ss.i also just had ALL umi adjustable suspension parts put on. i never planned on putting a cam in the car,but after all the suspension parts i am thinking i might do a cam as well.what size cam do you think will work well with the 1.85 rockers i have in now??? i do not want to do the heads!!!thanx john
Old Jun 30, 2006 | 09:13 AM
heymoej's Avatar
anybody????
Old Jun 30, 2006 | 10:19 AM
vettenuts's Avatar
With the rockers, I would look at some of the VHP/Crane cams. They were designed for use with the Crane 1.8 rockers and the ramp rates are likely setup for these higher acceleration rates.
Old Jun 30, 2006 | 10:54 AM
slow trap's Avatar
yes,keep something with mild lobes like the xe or similar from comp,the xer or lsk would be very aggressive with an 1.85 rocker.
Old Jun 30, 2006 | 11:28 AM
Ditmeion's Avatar
Just do the math....
lift / 1.7 * 1.85 = new lift
ie
.535 (orig lift) / 1.7 = .3147 * 1.85 = .582 (new lift)
Keep playing around till you come up with a lift that fits your needs and look for a cam with that lift...but with those rockers I probably wouldn't go for a cam over .550 ...that puts you close to .6 lift, in which those springs (918)are only good for
Old Jul 1, 2006 | 01:05 AM
heymoej's Avatar
cool thanx guys
