quick ? on putting center bolt heads on a 98 ls1
Old Jun 30, 2006 | 01:16 PM
MiaSSmaro98's Avatar
Default quick ? on putting center bolt heads on a 98 ls1
hey we all know the 98 ls1 is perimeter bolt pattern and now 99 up is center bolt.now i wanna put lq9 heads on my 98 ss for my boost project but ive been looking for some vavle covers, but there are diffrent models which one should i get.my 98 pass cover has 2 pipes to connect pcv stuff and most center bolt covers i seen only have one pipe in the front to connect to the t-body my 98 has 2 pipes now ive seen a center bolt with 2 pipes but never seen it again. i plan on getting a ls6 valley cover if this matter please help
Old Jun 30, 2006 | 01:43 PM
Ditmeion's Avatar
I did a 98->99+ valve cover swap & my valve covers had 2 fittings on Pass side & 1 on Drivers side. If you're doing the LS6 valley anyways, I wouldn't worry about your new valve covers not having those fittings, because you would plug them anyways...just need the one going from pass side to TB... did you see the writeup on http://www.ls1howto.com/index.php?article=18 ?
Old Jun 30, 2006 | 02:17 PM
thanks alot now i could buy center bolt covers with one pipe
Old Jul 6, 2006 | 09:52 PM
MIKE_84's Avatar
I'm doing the same thing on my 98, going to go with 01-02 valve covers with the matching valley cover and get rid of the nasty looking hose assembly, still going to run a catch can though.
Old Jul 7, 2006 | 10:37 AM
sounds cool
