oil pressure low
Old Jun 30, 2006 | 09:50 PM
smmurf86's Avatar
Default oil pressure low
i just did a heads/cam swap and put in an ls6 ported high volume oil pump....well when i start my car the pressure is about 70 until it gets warm and drops a lil bit. when im drivin it can get down to 30 or even as low as 20. wtf is up. thanks
" i saw a post about oil pressure a few down but it didnt really answer my question, im in a lil worse scenerio."
Old Jun 30, 2006 | 09:59 PM
smmurf86's Avatar
also i dont think this has much to do with anything but my battery is pretty dead..
im using 5w30 moblie1 fully synt.
Old Jun 30, 2006 | 10:46 PM
67Firebird455's Avatar
Have you actually checked the oil pressure with a mechanical gauge rather than the stocker? Try running something like 20-50 and see if that makes a huge difference. 70# startup is good, but under normal driving as long as its 10# per 1000rpm (ie 3k rpm = 30psi) you'll be fine. What happens when you rev to like 6000, does it jump to 70 again? Have you checked the o-ring on the oil pump, sounds a little like you're bleeding off oil pressure. Hope you find the culprit!
