Timing chain dampner in the way?
This is an LS2 Corvette.
Removing the steering rack and all on a C5 is a big deal making this more than a little worth it.
I'll bet MrEracer has his split covers on LS2s.
You should be able to see the dot in that photo....
You just have to get at the right angle...
After I found the dot I took a sharpie and drew a line out on the crank sprocket directly even with the dot. After you do this it is very easy to time it up
Would have liked to have kept the damper, but oh well......
